Datasheet Texas Instruments TMS320C6747CZKBD4 — Даташит
СерияTMS320C6747
МодельTMS320C6747CZKBD4
Процессор цифровых сигналов с фиксированной/плавающей запятой 256-BGA от -40 до 90
TMS320C6745, TMS320C6747 Fixed- and Floating-Point Digital Signal Processor datasheet
PDF, 2.0 Мб, Версия: F, Файл опубликован: 17 июн 2014
Pin256256
Package TypeZKBZKB
Industry STD TermBGABGA
JEDEC CodeS-PBGA-NS-PBGA-N
МаркировкаTMS320C6747CZKBD4
Width (мм)1717
Length (мм)1717
Thickness (мм)1.361.36
Pitch (мм)11
Max Height (мм)2.052.05
ApplicationsCommunications and Telecom
Approx. Price (US$)11.73 | 1ku
DRAMSDRAM
DSP1 C674x
DSP MHz (Max.)375
456
Display Options1
EMAC10/100
I2C2
On-Chip L2 Cache256 KB
Operating SystemsDSP/BIOS
Operating Temperature Range(C)-40 to 105
0 to 70
Other On-Chip Memory128 KB
SATA2
SPI2
UART(SCI)3
USB2
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSOSKL137
    OMAP-L137/TMS320C6747 Floating Point Starter Kit
    XDS200 USB Debug Probe
  • TMS320C6747 Technical Brief (Rev. B)
    PDF, 171 Кб, Версия: B, Файл опубликован: 18 фев 2009
    The C674x Floating-point Processor generation combines a new level of performance / precision and dynamic range with high power efficiency and system integration. The C674x processors are completely code compatible with other C67x processors.
  • Powering the TMS320C6745 and TMS320C6747 with the TPS650061
    PDF, 150 Кб, Файл опубликован: 25 окт 2011
  • TMS320C6747/45/43 Complementary Products
    PDF, 27 Кб, Файл опубликован: 23 сен 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/C6747/45/43_Complementary_Products .This Wiki article serves as a repository of complimentary dev
  • Using the TMS320C6747/45/43 Bootloader (Rev. C)
    PDF, 2.6 Мб, Версия: C, Файл опубликован: 1 июн 2012
    This application report describes various boot mechanisms supported by the C6747/45/43 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default s
  • TMS320C6747/45/43 Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 30 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/C6747/45/43_Power_Consumption_Summary.This article discusses the power consumption of the Texas Instruments TMS320C6747
  • Power Solution using a Dual DCDC Converter and a LDO (Rev. A)
    PDF, 174 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • Using the OMAP-L1x7 Bootloader (Rev. G)
    PDF, 2.6 Мб, Версия: G, Файл опубликован: 1 июн 2012
    This application report describes various boot mechanisms supported by the OMAP-L1x7 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default set
  • TMS320C6747/45/43 & OMAP-L1x7 USB Downstream Host Compliance Testing
    PDF, 2.8 Мб, Файл опубликован: 12 мар 2009
    This appication report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • TMS320C6747/45/43 & OMAP-L1x7 USB Upstream Device Compliance Testing
    PDF, 510 Кб, Файл опубликован: 12 мар 2009
    This application report describes the TMS320C674x/OMAP-L1x electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS), and low-speed (LS).
  • OMAP-L137 TMS320C6747/6745/6743 Pin Multiplexing Utility (Rev. A)
    PDF, 39 Кб, Версия: A, Файл опубликован: 26 сен 2009
    The OMAP-L137, C6747/6745/6743 devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyo
  • Power Solution Using Discrete DC/DC Converters and LDOs (Rev. B)
    PDF, 299 Кб, Версия: B, Файл опубликован: 26 авг 2010
  • Power Solution using LDO's (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > C674x DSP
На английском языке: Datasheet Texas Instruments TMS320C6747CZKBD4
