Datasheet Texas Instruments MC1558G — Даташит
СерияLM1558
МодельMC1558G
Двойной операционный усилитель 8-TO-99 от -55 до 125
LM1458/LM1558 Dual Operational Amplifier datasheet
PDF, 837 Кб, Версия: D, Файл опубликован: 27 мар 2013
Pin88
Package TypeLMCLMC
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MBCY-WO-MBCY-W
Package QTY500500
МаркировкаLM1558HLM1558H
Width (мм)9.089.08
Length (мм)9.089.08
Thickness (мм)4.44.4
Pitch (мм)2.542.54
Max Height (мм)5.725.72
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)70 дБ
CMRR(Typ)90 дБ
GBW(Typ)1 МГц
IIB(Max)500000 pA
Iq per channel(Max)2.5 мА
Iq per channel(Typ)1.5 мА
Количество каналов2
Output Current(Typ)45 мА
Package GroupTO-99
Package Size: mm2:W x L8TO-99: 80 mm2: 8.96 x 8.96(TO-99) PKG
Slew Rate(Typ)0.5 V/us
Total Supply Voltage(Max)44 +5V=5, +/-5V=10
Total Supply Voltage(Min)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)30 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
RoHSSee ti.com
  • AN-116 Use the LM158/LM258/LM358 Dual Single Supply Op Amp (Rev. B)
    PDF, 313 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note discusses the use of the LM158/LM258/LM358 dual op amp when operated from asingle supply.
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
Серия: LM1558 (3)
  • Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
На английском языке: Datasheet Texas Instruments MC1558G
