Datasheet Texas Instruments TLC5920DLRG4 — Даташит
| Серия | TLC5920 |
| Модель | TLC5920DLRG4 |
16-канальный светодиодный драйвер 48-SSOP от -20 до 85
16x8 LED Driver/Controller datasheet
PDF, 378 Кб, Версия: A, Файл опубликован: 9 сен 2002
Купить TLC5920DLRG4 на РадиоЛоцман.Цены — от 56 до 974 ₽11 предложений от 11 поставщиков IC LED DRIVER LINEAR 30MA 48SSOP. LED Driver IC 16 Output Linear Shift Register Dimming 30mA 48-SSOP. PMIC - LED Drivers... | |||
| TLC5920DLRG4 Texas Instruments | 56 ₽ | ||
| TLC5920DLRG4 Texas Instruments | по запросу | ||
| TLC5920DLRG4 | по запросу | ||
| Pin | 48 |
| Package Type | DL |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | TLC5920 |
| Width (мм) | 7.49 |
| Length (мм) | 15.88 |
| Thickness (мм) | 2.59 |
| Pitch (мм) | .635 |
| Max Height (мм) | 2.79 |
| Mechanical Data | Скачать |
| Ch to Ch Accuracy(Typ) | 6 +/- % |
| Data Transfer Rate(Typ) | 10 МГц |
| Рабочий диапазон температур | от -20 до 85 C |
| Package Group | SSOP |
| Package Size: mm2:W x L | 48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG |
| Rating | Catalog |
| Special Features | N/A |
- LED Driver--Paralleled Outputs Provide High Current OutputsPDF, 957 Кб, Файл опубликован: 25 сен 2006
This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
Серия: TLC5920 (4)
- TLC5920DL TLC5920DLG4 TLC5920DLR TLC5920DLRG4
- Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
