Datasheet Texas Instruments REG1117A-2.5G4 — Даташит
| Серия | REG1117A |
| Модель | REG1117A-2.5G4 |
1A Положительный регулятор с малым падением напряжения 4-SOT-223 0–125
REG1117: 800mA 1A Low Dropout Pos Regulator 1.8, 2.5, 2.85, 3.3, 5V, Adjustable datasheet
PDF, 846 Кб, Версия: D, Файл опубликован: 21 июл 2004
Купить REG1117A-2.5G4 на РадиоЛоцман.Цены — от 21 до 143 ₽8 предложений от 8 поставщиков Чип стабилизации напряжения, LDO Regulator Pos 2.5V 1A 4Pin(3+Tab) SOT-223 Rail | |||
| REG1117A-2.5G4 Texas Instruments | 44 ₽ | ||
| REG1117A-2.5G4 Texas Instruments | 143 ₽ | ||
| REG1117A-2.5G4 | по запросу | ||
| REG1117A-2.5G4 Texas Instruments | по запросу | ||
| Pin | 4 |
| Package Type | DCY |
| Industry STD Term | SOT-223 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 80 |
| Carrier | TUBE |
| Маркировка | R111725 |
| Width (мм) | 3.5 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1.6 |
| Pitch (мм) | 2.3 |
| Max Height (мм) | 1.8 |
| Mechanical Data | Скачать |
| Точность | 2 % |
| Fixed Output Options | 1.8,2.5,5 В |
| Iout(Max) | 1 A |
| Iq(Typ) | 4 мА |
| Noise | 38 uVrms |
| Рабочий диапазон температур | от 0 до 125 C |
| Output Capacitor Type | Non-Ceramic |
| Output Options | Adjustable Output,Fixed Output |
| PSRR @ 100KHz | 29 дБ |
| Package Group | SOT-223 |
| Package Size: mm2:W x L | 4SOT-223: 46 mm2: 7 x 6.5(SOT-223) PKG |
| Rating | Catalog |
| Regulated Outputs | 1 |
| Special Features | N/A |
| Thermal Resistance ОёJA | 65 В°C/W |
| Vdo(Typ) | 1200 мВ |
| Vin(Max) | 15 В |
| Vin(Min) | 3.7 В |
| Vout(Max) | 13.8 В |
| Vout(Min) | 1.25 В |
- An Easy Solution to Current Limiting an Op AmpPDF, 35 Кб, Файл опубликован: 2 окт 2000
Many circuits today not only require voltage regulation but they also need current regulation. Some systems draw excessive current during power on, which can cause expensive system components to burn up due to improper powering of supplies. This is not the only problem associated with excessive currents. Some applications need to limit the current an op amp can provide to a specific load. This cir - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - Packaging Limits Range of Linear RegulatorsPDF, 75 Кб, Файл опубликован: 8 май 2010
The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: REG1117A (24)
- REG1117A REG1117A-1.8 REG1117A-1.8/2K5 REG1117A-1.8G4 REG1117A-2.5 REG1117A-2.5/2K5 REG1117A-2.5G4 REG1117A/2K5 REG1117A/2K5G4 REG1117AG4 REG1117FA REG1117FA-1.8 REG1117FA-1.8KTTT REG1117FA-2.5 REG1117FA-2.5/500 REG1117FA-2.5KTTT REG1117FA-5.0 REG1117FA-5.0/500 REG1117FA-5.0KTTT REG1117FA-5.0KTTTG REG1117FA/500 REG1117FA1.8KTTTG3 REG1117FA2.5KTTTG3 REG1117FAKTTT
REG1117A2.5G4, REG1117A 2.5G4
