Datasheet Texas Instruments TS3A5223RSWR — Даташит
СерияTS3A5223
МодельTS3A5223RSWR
0.5Ω Dual SPDT Bidirectional Analog Switch 10-UQFN -40 to 85
TS3A5223 0.45 Ω 2-Channel SPDT Bidirectional Analog Switch datasheet
PDF, 957 Кб, Версия: B, Файл опубликован: 11 апр 2017
Pin10
Package TypeRSW
Industry STD TermUQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаB2A
Width (мм)1.4
Length (мм)1.8
Thickness (мм).45
Pitch (мм).4
Max Height (мм).55
Additional FeaturesBreak-before-make
Полоса частот80 МГц
Bandwidth(Max)80 МГц
Configuration2:1 SPDT
ESD Charged Device Model0.5 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)3.6 В
Input/Output Continuous Current(Max)300 мА
Input/Output OFF-state Capacitance(Typ)50 пФ
Input/Output ON-state Capacitance(Typ)115 пФ
Количество каналов2
OFF-state leakage current(Max)0.09 мкА
ON-state leakage current(Max)0.06 мкА
Package GroupUQFN
Package Size: mm2:W x L10UQFN: 3 mm2: 1.4 x 1.8(UQFN) PKG
Ron(Max)1.2 Ohms
Ron(Typ)0.45 Ohms
Supply Current(Max)220 uA
Supply Current(Typ)150 uA
Supply Range3.6 Max
VIH(Min)0.8 В
VIL(Max)0.3 В
Vdd(Max)3.6 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3A5223 (1)
  • TS3A5223RSWR
На английском языке: Datasheet Texas Instruments TS3A5223RSWR
