Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments ADS7824UBE4 — Даташит
СерияADS7824
МодельADS7824UBE4
4-канальный 12-битный КМОП аналого-цифровой преобразователь 28-SOIC от -40 до 85
4-Channel, 12-Bit Sampling CMOS A/D Converter datasheet
PDF, 800 Кб, Файл опубликован: 27 сен 2000
АЦП азиатских производителей
Pin2828
Package TypeDWDW
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY2020
CarrierTUBETUBE
МаркировкаBADS7824U
Width (мм)7.57.5
Length (мм)17.917.9
Thickness (мм)2.352.35
Pitch (мм)1.271.27
Max Height (мм)2.652.65
# Input Channels4
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)4.75 В
INL(Max)0.5 +/-LSB
Input Range(Max)10 В
Input Range(Min)-10 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceParallel,Serial
Package Size: mm2:W x L28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG
Power Consumption(Typ)50 mW
Reference ModeExt,Int
Разрешение12 Bits
SINADN/A дБ
SNR73 дБ
Sample Rate (max)40kSPS SPS
Sample Rate(Max)0.04 MSPS
THD(Typ)-90 дБ
  • Using the Continuos Parallel Mode with the ADS7824 and ADS7825
    PDF, 57 Кб, Файл опубликован: 27 сен 2000
    The ADS7824 and ADS7825 are 12-bit and 16-bit converters that have a four channel multiplexed front end. The channel selection on the analog input of these converters is programmable by way of the pins on the devices, A0 and A1. This feature provides the most flexibility by allowing the user to change to the preferred input channel on the fly. Additionally, the input channels can be cycled by util
  • ADS7809 Tag Features
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    The ADS7809 is part of a family of capacitive redistribution SAR A/D converters that feature a serial output and a tag pin for cascading multiple converters. Other members of this family include the ADS7806, ADS7807, ADS7808, ADS7824, and ADS7825. Note that the even numbered converters are 12-bit converters and the odd numbered converters are 16-bit converters.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7824 (4)
На английском языке: Datasheet Texas Instruments ADS7824UBE4
