Datasheet Texas Instruments 5962-9455501M3A — Даташит
СерияUC1875
Модель5962-9455501M3A
Резонансный регулятор фазового сдвига 28-LCCC от -55 до 125
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Pin28282828
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка883B5962-UC1875L/9455501M3A
Width (мм)11.4311.4311.4311.43
Length (мм)11.4311.4311.4311.43
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
Control MethodCurrent,Feedforward,Voltage
Duty Cycle(Max)100 %
Frequency(Max)1000 kHz
Package GroupLCCC
Package Size: mm2:W x L28LCCC: 131 mm2: 11.43 x 11.43(LCCC) PKG
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Soft Switching,Synchronization Pin
TopologyFull-Bridge
UVLO Thresholds On/Off10/7 В
Vin(Max)20 В
Vin(Min)9.25 В
RoHSSee ti.com
  • Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)
    PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
    This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform
Серия: UC1875 (6)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
59629455501M3A, 5962 9455501M3A
На английском языке: Datasheet Texas Instruments 5962-9455501M3A
