Datasheet Texas Instruments LM5030MM/NOPB — Даташит
СерияLM5030
МодельLM5030MM/NOPB
ШИМ-контроллер двухтактного режима тока 100 В 10-VSSOP от -40 до 125
LM5030 100-V Push-Pull Current Mode PWM Controller datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 24 ноя 2015
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY1000
МаркировкаS73B
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Control MethodCurrent
Duty Cycle(Max)49 %
Frequency(Max)1000 kHz
Frequency(Min)50 kHz
Gate Drive(Typ)1.5 A
Package GroupVSSOP
Special FeaturesMulti-topology,Programmable Slope Compensation,Synchronization Pin
TopologyFull-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7.6/~5.95 В
Vin(Max)90 В
Vin(Min)14 В
  • Evaluation Modules & Boards: LM5030EVAL
    100V Push-Pull Current Mode PWM Controller
  • Is Your IGBT Gate-Driver Power Supply Optimized
    PDF, 115 Кб, Файл опубликован: 12 мар 2015
    Insulated Gate Bipolar Transistors (IGBTs) are used in high current three-phase AC motors. This application report discusses the theory and requirements of gate-drive power supply for IGBTs. It also discusses the isolation requirements and calculation of correct amount of IGBT drive power.
  • LM5030 Application: DC - DC Converter Utilizing the Push-Pull Topology
    PDF, 329 Кб, Файл опубликован: 21 мар 2007
Серия: LM5030 (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments LM5030MM/NOPB
