Datasheet ТI ADS8382IBRHPTG4 — Даташит
| Серия | ADS8382 |
| Модель | ADS8382IBRHPTG4 |
18-битный последовательный АЦП, 600 KSPS с опорным и псевдобиполярным, полностью дифференциальным входом 28-VQFN от -40 до 85
ADS8382: 18-Bit 600-kHz Unipolar Differential Input Micropower Sampling ADC datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 3 ноя 2004
- Using the ADS8382 With the TMS320C6713 DSPPDF, 193 Кб, Файл опубликован: 24 мар 2005
This application report presents a solution to interfacing the ADS8382 18-bit, 600-KSPS serial interface converter to the TMS320C6713 DSP. The hardware solution is made up of existing hardware: the ADS8382EVM, 'C6713 DSK, and 5-6K Interface Board. The software demonstrates how to use an EDMA and Timer peripheral to collect data at 598 kHz. Discussed also are some of the key points to remember when - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8382 (3)
- ADS8382IBRHPT ADS8382IBRHPTG4 ADS8382IRHPT
