Datasheet Texas Instruments TPS26600PWPT — Даташит
СерияTPS2660
МодельTPS26600PWPT
Промышленный предохранитель eFuse, 60 В, 2 А, со встроенной защитой от обратной полярности входа, 16-HTSSOP от -40 до 125
TPS2660x 60-V, 2-A Industrial eFuse With Integrated Reverse Input Polarity Protection datasheet
PDF, 4.0 Мб, Версия: D, Файл опубликован: 7 апр 2017
Pin16
Package TypePWP
Industry STD TermHTSSOP
Package QTY250
CarrierSMALL T&R
Маркировка26600
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Channel(s) Controlled1
Current Limit Accuracy+/-5% @1A
Current Limit Function EnabledAlways
Current Limit TypeAdjustable
Current Limit(Max)2.23 A
Current Limit(Min)0.1 A
FET ProtectionSOA,Thermal
Fault ResponseAuto Retry,Latch Off
Imax2 A
Количество каналов1
Overcurrent ResponseCurrent Limiting, Circuit Breaker with Auto Retry
Overvoltage ResponseCut-Off
Package GroupHTSSOP
Package Size: mm2:W x L16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) PKG
Rise Time(Typ)Adjustable us
Ron(Typ)150 mOhm
Special FeaturesAdjustable Rise Time,Analog IMON Output,Current Sense/Monitor,Fault Reporting,Low Iq Shutdown,No RSENSE Required,No Reverse Current When Off,Over Current Reporting,Over Temp Reporting,Overvoltage Protection,Power MUXing,Reverse Current Blocking,Reverse Current Protection,Thermal Shutdown,Undervoltage Protection,dV/dT
UL RecognitionYes
Vabsmax_cont60 В
Vin(Max)55 В
Vin(Min)4.2 В
  • Evaluation Modules & Boards: TPS26600-02EVM
    TPS2660 Integrated 60V 2.23A Industrial eFuse Evaluation Module
  • The TPS2660 Simplifies Surge and Power-Fail Protection Circuits in PLC System
    PDF, 9.9 Мб, Файл опубликован: 25 окт 2016
    The Programmable Logic Controller (PLC) system is usually connected to an external DC power supply to provide power to the controller unit, backplane and I/O modules. The input protection circuits are required to protect the PLC from various faults that may occur either on the field or the PLC side. Traditionally, discrete or semi-integrated circuits have been the solution and require a lot of ext
  • Power Multiplexing Using Load Switches and eFuses (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 20 июн 2017
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS26600PWPT
