Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS61020DRCRG4 — Даташит
СерияTPS61020
МодельTPS61020DRCRG4
Регулируемый переключатель на 1,5 А, повышающий преобразователь с КПД 96 % и режимом понижения, QFN-10 10-VSON от -40 до 85
TPS6102x 96% Efficient Synchronous Boost Converter datasheet
PDF, 1.2 Мб, Версия: G, Файл опубликован: 24 дек 2014
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаBDR
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Duty Cycle(Max)100 %
Iq(Typ)0.025 мА
Package GroupVSON
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Load Disconnect,Power Good
Switch Current Limit(Min)1.2 A
Switch Current Limit(Typ)1.5 A
Switching Frequency(Max)720 kHz
Switching Frequency(Min)480 kHz
ТипConverter
Vin(Max)6.5 В
Vin(Min)0.9 В
Vout(Max)5.5 В
Vout(Min)1.8 В
  • Evaluation Modules & Boards: TPS61020EVM-025
    TPS61020 Evaluation Module
  • TPS61020 Boost Converter Start-Up and Precharge
    PDF, 488 Кб, Файл опубликован: 28 янв 2010
    The TPS61020 is a highly integrated, low-power, boost converter ideally suited for portable battery-powered equipment. To improve start-up performance from a power-limited source such as a battery, the TPS6102x family uses different steps and modes to reduce demand on the battery. This prevents the battery bus from sagging during start-up and improves start-up operation at low voltage.
  • Factors That Determine Light Load PSM Switch Freq for TPS6102x Boost Converters
    PDF, 528 Кб, Файл опубликован: 21 апр 2006
  • TPS6102x Boost Converter Down Conversion Mode
    PDF, 159 Кб, Файл опубликован: 16 дек 2004
    The TPS61020 is a highly integrated, low-power, boost converter ideally suited for portable battery-powered equipment. The integrated down conversion mode allows the boost converter to operate with the input voltage greater than the output voltage, which is normally only possible with more complicated converters.
  • Calculating and Measuring the No Load Input Current of the Boost Converter
    PDF, 143 Кб, Файл опубликован: 23 сен 2016
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS61020 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61020DRCRG4
