Datasheet Texas Instruments OPA2338EA/250G4 — Даташит
Серия | OPA2338 |
Модель | OPA2338EA/250G4 |
MicroSIZE, операционный усилитель КМОП с однополярным питанием Серия микроусилителей 8-SOT-23
MicroSIZE, Single-Supply CMOS Operational Amplifiers MicroAmplifier Series datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 9 мар 2005
![]() 8 предложений от 8 поставщиков Микросхема Буферный усилитель, IC OPAMP GP 12.5MHz RRO SOT23-8 | |||
OPA2338EA/250G4 Texas Instruments | 48 ₽ | ||
OPA2338EA/250G4 Texas Instruments | 83 ₽ | ||
OPA2338EA/250G4 Texas Instruments | по запросу | ||
OPA2338EA/250G4 | по запросу |
Pin | 8 |
Package Type | DCN |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Width (мм) | 1.63 |
Length (мм) | 2.9 |
Thickness (мм) | 1.1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Additional Features | Decompensated |
Approx. Price (US$) | 0.60 | 1ku |
Архитектура | CMOS |
CMRR(Min)(dB) | 74 |
CMRR(Typ)(dB) | 90 |
GBW(Typ)(MHz) | 62.5 |
Input Bias Current(Max)(pA) | 10 |
Iq per channel(Max)(mA) | 1 |
Iq per channel(Typ)(mA) | 0.525 |
Number of Channels(#) | 2 |
Offset Drift(Typ)(uV/C) | 2 |
Operating Temperature Range(C) | -40 to 85 |
Output Current(Typ)(mA) | 9 |
Package Group | SOT-23 |
Package Size: mm2:W x L (PKG) | 8SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
Rail-to-Rail | In to V- Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 4.6 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 5.5 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 2.7 |
Vn at 1kHz(Typ)(nV/rtHz) | 26 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 3 |
RoHS | Не совместим |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2338 (8)
- OPA2338EA/250 OPA2338EA/250G4 OPA2338EA/3K OPA2338EA/3KG4 OPA2338UA OPA2338UA/2K5 OPA2338UA/2K5G4 OPA2338UAG4
