Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74CBTD1G125DCKR — Даташит
СерияSN74CBTD1G125
МодельSN74CBTD1G125DCKR
Одиночный переключатель шины на полевом транзисторе со сдвигом уровня 5-SC70 от -40 до 85
SN74CBTD1G125 datasheet
PDF, 846 Кб, Версия: L, Файл опубликован: 29 мар 2006
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаPMR
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)10 Mhz
Gate TypeBUS SWITCH
ICC @ Nom Voltage(Max)1.5 мА
LogicTrue
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesSPST switch,low tpd,unbuffered,low Ron,3-state,translation
Sub-FamilyDigital Switch/Mux/Demux
Technology FamilyCBT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)0.25 нс
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74CBTD1G125DCKR
