Datasheet Texas Instruments LM2903QPWRQ1 — Даташит
| Серия | LM2903-Q1 |
| Модель | LM2903QPWRQ1 |
Автомобильный каталог Двойной дифференциальный компаратор 8-TSSOP от -40 до 125
LM2903-Q1 Dual Differential Comparators datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 8 июл 2014
Купить LM2903QPWRQ1 на РадиоЛоцман.Цены — от 6.05 до 96 ₽45 предложений от 19 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LM2903QPWRQ1 Analogue Comparator, Dual, Differential, 2, 1.3µs, 2V to 30V, TSSOP, 8Pins | |||
| LM2903QPWRQ1 Texas Instruments | от 6.05 ₽ | ||
| LM2903QPWRQ1 Texas Instruments | от 45 ₽ | ||
| LM2903QPWRQ1 | по запросу | ||
| LM2903QPWRQ1 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | 2903Q1 |
| Width (мм) | 4.4 |
| Length (мм) | 3 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Input Bias Current (+/-)(Max) | 50 нА |
| Iq per channel(Max) | 0.5 мА |
| Количество каналов | 2 |
| Тип выхода | Open Collector |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG |
| Propagation Delay Time | 1.3 uS |
| Rail-to-Rail | Out |
| Rating | Automotive |
| Special Features | N/A |
| VICR(Max) | 30.5 В |
| Vos (Offset Voltage @ 25C)(Max) | 7 мВ |
| Vs(Max) | 30 В |
| Vs(Min) | 2 В |
- Designing Overcurrent protection for TPL7407L Peripheral DriverPDF, 177 Кб, Файл опубликован: 5 ноя 2014
Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
Серия: LM2903-Q1 (13)
- Semiconductors > Amplifiers > Comparators
