Datasheet Texas Instruments TPS259230DRCR — Даташит
Серия | TPS25923 |
Модель | TPS259230DRCR |
5V, 5A, 28mО© eFuse with BFET Driver for Reverse Current Protection 10-VSON -40 to 85
TPS25923x 5-V eFuse with Over Voltage Protection and Blocking FET Control datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 2 сен 2016
Pin | 10 |
Package Type | DRC |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 259230 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Current Limit Accuracy | +/-8% |
Current Limit Function Enabled | Always |
Current Limit Type | Adjustable |
Current Limit(Max) | 5 A |
Current Limit(Min) | 1 A |
FET Protection | Thermal |
Fault Response | Latch Off |
Imax | 5 A |
Количество каналов | 1 |
ON_OFF Control Input | ENUV s |
Overcurrent Response | Current Limiting |
Overvoltage Response | Clamp |
Package Group | VSON |
Package Size: mm2:W x L | 10VSON: 9 mm2: 3 x 3(VSON) PKG |
Rise Time(Typ) | 400 us |
Ron(Typ) | 28 mOhm |
Special Features | Overvoltage Protection,Reverse Current Protection,Thermal Shutdown,Under Voltage Lock Out |
UL Recognition | Yes |
Vabsmax_cont | 20 В |
Vin(Max) | 5.5 В |
Vin(Min) | 4.5 В |
- Evaluation Modules & Boards: TPS259230-41EVM
TPS25923/4/7, Simple 5V/12V eFuse Protection Switches Evaluation Module
Серия: TPS25923 (4)
- TPS259230DRCR TPS259230DRCT TPS259231DRCR TPS259231DRCT
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
