Datasheet Texas Instruments TPS60255RTER — Даташит
СерияTPS60255
МодельTPS60255RTER
7-канальный высокоэффективный зарядный насос с током 175 мА и белой светодиодной подсветкой 16-WQFN от -40 до 85
HIGH EFFICIENCY CHARGE PUMP FOR 7 WLEDs DRIVER WITH 1 WIRE INTERFACE datasheet
PDF, 926 Кб, Файл опубликован: 24 мар 2008
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаBUP
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Количество каналов7
Duty Cycle(Max)100 %
LED4+2+1
LED Current Per Channel25 мА
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 9 mm2: 3 x 3(WQFN) PKG
Peak Efficiency93 %
Shutdown Current(Typ)0.1 uA
Special FeaturesAnalog Dimming,EasyScale 1-Wire Interface,Enable/Shutdown,Fault Detection,Integrated Switch,Load Disconnect During Shutdown,OVP,Soft Start,Synchronous Rectification
Switching Frequency(Max)875 kHz
TopologyBoost
ТипCapacitive
Vin(Max)6 В
Vin(Min)2.7 В
Vout(Max)6.5 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS60255EVM-262
    TPS60255EVM-262 Evaluation Module
  • Ballast Resistor Calculation – Current Matching in Parallel LEDs
    PDF, 351 Кб, Файл опубликован: 16 апр 2009
    Engineers often need to connect LEDs in parallel. Ideally, the LEDs share current equally. In reality, even LEDs from the same production lot have poorly matched I-V characteristics. This mismatch causes the LEDs to not share the current equally. The engineer can add a ballast resistor in series with each LED to minimize current differences. This application report explains how to size the ball
Серия: TPS60255 (2)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS60255RTER
