Datasheet Texas Instruments ADS8329IRSAR — Даташит
Серия | ADS8329 |
Модель | ADS8329IRSAR |
2,7–5,5 В, 16 бит, 1 MSPS, последовательный АЦП 16-QFN от -40 до 85
Low-Power, 16-Bit, 1-MHz, Single/Dual Unipolar Input, ADCs w/ Serial Interface datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 7 июл 2009
![]() 22 предложений от 16 поставщиков IC ADC 16BIT SAR 16QFN. 16 Bit Analog to Digital Converter 1 Input 1 SAR 16-QFN (4x4). Data Acquisition - Analog... | |||
ADS8329IRSAR Texas Instruments | 1 216 ₽ | ||
ADS8329IRSAR Texas Instruments | от 2 111 ₽ | ||
ADS8329IRSAR Texas Instruments | по запросу | ||
Pin | 16 | 16 |
Package Type | RSA | RSA |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 2000 | 2000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | ADS | 8329I A |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1 | 1 |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 2.7 В |
Архитектура | SAR |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 1.65 В |
INL(Max) | 1.75 +/-LSB |
Input Range(Max) | 5.5 В |
Тип входа | Differential,Single-Ended |
Integrated Features | Daisy-Chainable,Oscillator |
Interface | SPI |
Multi-Channel Configuration | N/A |
Package Group | QFN |
Package Size: mm2:W x L | 16QFN: 16 mm2: 4 x 4(QFN) PKG |
Power Consumption(Typ) | 13.2 mW |
Rating | Catalog |
Reference Mode | Ext |
Разрешение | 16 Bits |
SINAD | 92 дБ |
SNR | 93 дБ |
Sample Rate (max) | 1MSPS SPS |
Sample Rate(Max) | 1 MSPS |
THD(Typ) | -102 дБ |
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8329 (11)
