Datasheet Texas Instruments TMS320C6454BCTZ8 — Даташит
СерияTMS320C6454
МодельTMS320C6454BCTZ8
Процессор цифровых сигналов с фиксированной точкой 697-FCBGA
TMS320C6454 Fixed-Point Digital Signal Processor datasheet
PDF, 1.5 Мб, Версия: I, Файл опубликован: 28 мар 2012
Pin697697697697
Package TypeCTZCTZCTZCTZ
Package QTY44444444
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка320C6454BCTZ@2005 TITMS8
Width (мм)24242424
Length (мм)24242424
Thickness (мм)2.652.652.652.65
  • Development Kits: TMDXEVM6455
    TMS320C6455 Evaluation Module
  • Evaluation Modules & Boards: TMDSDSK6455
    TMS320C6455 DSP Starter Kit (DSK)
  • Evaluation Modules & Boards: TMDXEVM6452
    C6452 DSP Evaluation Module
  • JTAG Emulators/ Analyzers: XDS560TRACE
    XDS560 Trace Emulator
    XDS200 USB Debug Probe
  • EDMA v3.0 (EDMA3) Migration Guide for TMS320C645x DSP
    PDF, 343 Кб, Файл опубликован: 23 дек 2005
    The TMS320C645x devices introduce a newly designed Enhanced Direct Memory Access (EDMA3). The EDMA3 has many new features that improve system performance and enhance debugging capabilities. This document summarizes the key differences between EDMA3 on the TMS320C645x devices and EDMA2 on the TMS320C64x devices. This document also provides guidance for migrating from EDMA2 to EDMA3.
  • TMS320C64x+ Megamodule
    PDF, 122 Кб, Файл опубликован: 16 ноя 2004
    The C64X+ Megamodule supports a wide variety of internal memory configurations by allowing the L1 program and data memory (L1P and L1D) to set as cache only, SRAM only, or a mixture of cache and SRAM. In addition, the C64x+ Megamodule provides new system functionality including: cache freeze, Internal DMA (IDMA), bandwidth management, and memory protection. This document discusses the enhancements
  • Preparing an C645x application for I2C Boot Load
    PDF, 85 Кб, Файл опубликован: 5 сен 2006
    This application report describes how to prepare a C645x application for the I2C boot load process.The enclosed .zip archive contains all utilities and examples necessary to build a test application, program it into DSK6455's I2C ROM, change the boot mode to I2C boot load, and verify that the test application has been loaded from the I2C and is running correctly.
  • SW Operation of Gigabit Ethernet Media Access Controller on TMS320C645x DSP
    PDF, 288 Кб, Файл опубликован: 31 окт 2006
    The TMS645x devices provide an efficient interface between the DSP core processor and the network via a high performance Gigabit Ethernet Media Access Controller (EMAC), supporting four Media Independent Interfaces to the physical layer device (PHY).This application report discusses the software interface used to operate the EMAC and Management Data Input/Output (MDIO) modules. It describes i
  • TMS320C6455/C6454 Power Consumption Summary (Rev. B)
    PDF, 75 Кб, Версия: B, Файл опубликован: 1 окт 2007
    This application report discusses the power consumption of the Texas Instruments TMS320C6455 and TMS320C6454 digital signal processor (DSPs). The power consumption on the C645x devices is highly application-dependent, therefore, a power spreadsheet that predicts power consumption is provided along with this application note. The power spreadsheet can be used for the purpose of modeling power consu
  • Implementing DDR2 PCB Layout on the TMS320C6455/C6454 (Rev. E)
    PDF, 158 Кб, Версия: E, Файл опубликован: 8 июл 2008
    This application report contains implementation instructions for the DDR2 interface contained on the TMS320C6454/5 digital signal processor (DSP) device. The approach to specifying interface timing for the DDR2 interface is quite different than on previous devices.The previous approach specified device timing in terms of data sheet specifications and simulation models. The system designer was
  • Error Detection and Correction Mechanism of TMS320C64x+/C674x (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 19 июл 2013
    This application report describes the error detection and correction mechanism of the C64x+/C674x megamodule L1P and L2 memories implemented on some devices. Depending on the type of application, these mechanisms are used to either provide diagnostic measures to detect faults in the memory that could lead to unacceptable risk for the user or to increase the availability of the system.
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • TMS320C64x to TMS320C64x+ CPU Migration Guide (Rev. A)
    PDF, 310 Кб, Версия: A, Файл опубликован: 20 окт 2005
    This document describes migration from the Texas Instruments TMS320C64xв„ў digital signal processor (DSP) to the TMS320C64x+в„ў DSP. The objective of this document is to indicate differences between the two cores and to briefly describe new features. Functionality in the devices that is identical is not included. For detailed information about either device, see the TMS320C64x/C64x+ DSP
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMS320C6454BCTZ8
