Datasheet Texas Instruments TPS7201QPWLE — Даташит
СерияTPS72
МодельTPS7201QPWLE
Микромощные регуляторы напряжения с малым падением напряжения (LDO) 250 мА 8-TSSOP от -40 до 125
MicroPower Low-Dropout (LDO) Voltage Regulators datasheet
PDF, 1.5 Мб, Версия: G, Файл опубликован: 5 июн 2000
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementTPS7201QPWR
Replacement CodeS
Accuracy(%)2
Additional FeaturesEnable
Overcurrent Protection
Power Good
Thermal Shutdown
Approx. Price (US$)0.68 | 1ku
Fixed Output Options(V)2.5
3
3.3
4.8
5
Iout(Max)(A)0.25
Iq(Typ)(mA)0.18
Operating Temperature Range(C)-40 to 125
-55 to 150
Output OptionsAdjustable Output
Fixed Output
Package GroupTSSOP
Regulated Outputs(#)1
Vdo(Typ)(mV)560
Vin(Max)(V)10
Vin(Min)(V)3
Vout(Max)(V)9.75
Vout(Min)(V)1.2
RoHSНе совместим
  • Evaluation Modules & Boards: ASLKPRO
    ASLKPRO University Kit
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS7201QPWLE
