Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM1458MX/NOPB — Даташит
СерияLM1458
МодельLM1458MX/NOPB
Двойной операционный усилитель 8-SOIC от 0 до 70
LM1458/LM1558 Dual Operational Amplifier datasheet
PDF, 837 Кб, Версия: D, Файл опубликован: 27 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка1458MLM
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)70 дБ
CMRR(Typ)90 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)500000 pA
Iq per channel(Max)2.8 мА
Iq per channel(Typ)1.5 мА
Количество каналов2
Output Current(Typ)45 мА
Rail-to-RailNo
Slew Rate(Typ)0.5 V/us
Total Supply Voltage(Min)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)30 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)6 мВ
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-116 Use the LM158/LM258/LM358 Dual Single Supply Op Amp (Rev. B)
    PDF, 313 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note discusses the use of the LM158/LM258/LM358 dual op amp when operated from asingle supply.
На английском языке: Datasheet Texas Instruments LM1458MX/NOPB
