Datasheet Texas Instruments SN74CB3T3253DBQR — Даташит
Серия | SN74CB3T3253 |
Модель | SN74CB3T3253DBQR |
Двойной низковольтный переключатель шины Mult/Demult 1 из 4 на полевых транзисторах 2,5 В/3,3 В с толерантным устройством сдвига уровня 5 В 16-SSOP от -40 до 85
Pin | 16 |
Package Type | DBQ |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | KS253 |
Width (мм) | 3.9 |
Length (мм) | 4.9 |
Thickness (мм) | 1.5 |
Pitch (мм) | .64 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Powered off protection,Signal path Translation |
Полоса частот | 100 МГц |
Bandwidth(Max) | 100 МГц |
Configuration | 4:1 |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 5 пФ |
Input/Output ON-state Capacitance(Typ) | 4 пФ |
Количество каналов | 2 |
OFF-state leakage current(Max) | 10 мкА |
Package Group | SSOP |
Package Size: mm2:W x L | 16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG |
Rating | Catalog |
Ron(Max) | 8 Ohms |
Ron(Typ) | 5 Ohms |
Supply Current(Max) | 20 uA |
Supply Range | 3.6 Max |
VIH(Min) | 1.7 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 3.6 В |
Vdd(Min) | 2.3 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- CBT-C, CB3T, and CB3Q Signal-Switch FamiliesPDF, 584 Кб, Файл опубликован: 4 фев 2003
Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot - Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CB3T3253 (7)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
