Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI ADC12D1800RFIUT — Даташит
СерияADC12D1800RF
МодельADC12D1800RFIUT
Datasheet Texas Instruments ADC12D1800RFIUT
12-битный аналого-цифровой преобразователь (АЦП) с двойной частотой 1,8-GSPS или одинарной частотой 3,6-SPS с радиочастотной дискретизацией 292-BGA от -40 до 85
ADC12D1800RF 12-Bit, Single 3.6 GSPS RF Sampling ADC datasheet
PDF, 3.6 Мб, Версия: J, Файл опубликован: 11 ноя 2014
  • Signal Chain Noise Figure Analysis
    PDF, 615 Кб, Файл опубликован: 29 окт 2014
  • Wide Bandwidth Receiver Implementation by Interleaving Two Giga-Sampling ADCs
    PDF, 621 Кб, Файл опубликован: 7 дек 2015
  • Synchronizing the Giga-Sample ADCs Interfaced with Multiple FPGAs
    PDF, 943 Кб, Файл опубликован: 6 авг 2014
  • AN-2128 ADC1xD1x00 Pin Compatibility (Rev. C)
    PDF, 60 Кб, Версия: C, Файл опубликован: 1 май 2013
    In order to facilitate upgrading applications from a 10-bit Gig ADC to a 12-bit Gig ADC, the ADC10D1x00(ADC10D1500/ADC10D1000) is designed to be pin-compatible with the ADC12D1x00(ADC12D1800/1600/1000). This means that a single board layout may be designed with both resolutionADCs in mind for more cost efficient and time-to-market product development.
  • AN-2177 Using the LMH6554 as a ADC Driver (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses the use of the Texas Instruments LMH6554 as an ADC driver.
  • From Sample Instant to Data Output: Understanding Latency in the GSPS ADC
    PDF, 392 Кб, Файл опубликован: 18 дек 2012
    For many applications which use ultra high-speed ADCs, latency can be a critical performance specification. For example, if the ADC is used in any kind of feedback loop, then the absolute latency is an important factor. For a MIMO system such as a phased array radar, the relative difference and variability in latency becomes important. This application note covers latency in the GSPS ADC products,
  • AN-2132 Synchronizing Multiple GSPS ADCs in a System: The AutoSync Feature (Rev. G)
    PDF, 169 Кб, Версия: G, Файл опубликован: 3 фев 2017
  • Maximizing SFDR Performance in the GSPS ADC: Spur Sources and Methods of Mitigat
    PDF, 720 Кб, Файл опубликован: 9 дек 2013
    The SFDR performance of an ADC is limited by the largest spur in the spectrum from DC to Fs / 2. These spurs can either be reduced or avoided entirely for maximum SFDR performance, based on the application. This reference design explores the reason behind spurs in the 10-bit and 12-bit GSPS ADCfamily. The specific products covered are: ADC12D1800RF, ADC12D1600RF, ADC12D1000RF, ADC12D800RF, ADC12
Серия: ADC12D1800RF (2)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADC12D1800RFIUT
Политика конфиденциальности
