Datasheet Texas Instruments TPS25921LDR — Даташит
| Серия | TPS25921L |
| Модель | TPS25921LDR |
18V, 1.6A, 90mО© eFuse with Adjustable +/-2% Accurate Current Limit 8-SOIC -40 to 85
TPS25921x 4.5V - 18V eFuse with Precise Current Limit and Over Voltage Protection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 ноя 2015
Купить TPS25921LDR на РадиоЛоцман.Цены — от 18 до 233 ₽36 предложений от 15 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Устройства горячей замены | |||
| TPS25921LDR Texas Instruments | от 53 ₽ | ||
| TPS25921LDR Texas Instruments | 55 ₽ | ||
| TPS25921LDR Texas Instruments | 72 ₽ | ||
| TPS25921LDR Texas Instruments | 122 ₽ | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | 25921L |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Channel(s) Controlled | 1 |
| Current Limit Accuracy | +/-2% |
| Current Limit Function Enabled | Always |
| Current Limit Type | Adjustable |
| Current Limit(Max) | 1.6 A |
| Current Limit(Min) | 0.4 A |
| FET Protection | Thermal |
| Fault Response | Latch Off |
| Imax | 1.6 A |
| Количество каналов | 1 |
| ON_OFF Control Input | ENUV,OV s |
| Overcurrent Response | Current Limiting |
| Overvoltage Response | Cutoff |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Rise Time(Typ) | 260 us |
| Ron(Typ) | 90 mOhm |
| Special Features | Fault Reporting,Overvoltage Protection,Thermal Shutdown,Under Voltage Lock Out |
| UL Recognition | Yes |
| Vabsmax_cont | 20 В |
| Vin(Max) | 18 В |
| Vin(Min) | 4.5 В |
- Evaluation Modules & Boards: TPS25921EVM-637
TPS25921EVM-637 4.5-18V eFuse with Precision Current Limit Evaluation Module
Серия: TPS25921L (2)
- TPS25921LD TPS25921LDR
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
