Datasheet Texas Instruments SN74AUP1G07DCKRG4 — Даташит
| Серия | SN74AUP1G07 |
| Модель | SN74AUP1G07DCKRG4 |
Одиночный буфер/драйвер малой мощности с выходами с открытым стоком 5-SC70 от -40 до 85
SN74AUP1G07 Low-Power Single Buffer/Driver With Open-Drain Outputs datasheet
PDF, 1.6 Мб, Версия: J, Файл опубликован: 13 дек 2013
Купить SN74AUP1G07DCKRG4 на РадиоЛоцман.Цены — от 6.38 до 33 ₽14 предложений от 11 поставщиков IC BUF NON-INVERT 3.6V SC70-5. Buffer, Non-Inverting 1 Element 1 Bit per Element Open Drain Output SC-70-5. Logic - Buffers, Drivers,... | |||
| SN74AUP1G07DCKRG4 Texas Instruments | 6.38 ₽ | ||
| SN74AUP1G07DCKRG4 Texas Instruments | 12 ₽ | ||
| SN74AUP1G07DCKRG4 Texas Instruments | от 32 ₽ | ||
| SN74AUP1G07DCKRG4 Texas Instruments | по запросу | ||
| Pin | 5 | 5 | 5 | 5 |
| Package Type | DCK | DCK | DCK | DCK |
| Industry STD Term | SOT-SC70 | SOT-SC70 | SOT-SC70 | SOT-SC70 |
| JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
| Package QTY | 3000 | 3000 | 3000 | 3000 |
| Carrier | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R |
| Маркировка | HVK | HVF | HV5 | HVR |
| Width (мм) | 1.25 | 1.25 | 1.25 | 1.25 |
| Length (мм) | 2 | 2 | 2 | 2 |
| Thickness (мм) | .9 | .9 | .9 | .9 |
| Pitch (мм) | .65 | .65 | .65 | .65 |
| Max Height (мм) | 1.1 | 1.1 | 1.1 | 1.1 |
| Mechanical Data | Скачать | Скачать | Скачать | Скачать |
| 3-State Output | No |
| Bits | 1 |
| F @ Nom Voltage(Max) | 100 Mhz |
| Gate Type | OPEN DRAIN BUFFER |
| ICC @ Nom Voltage(Max) | 0.0009 мА |
| Logic | True |
| Output Drive (IOL/IOH)(Max) | 4/-4 мА |
| Package Group | SC70 |
| Package Size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2(SC70) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Special Features | IOFF,low power consumption,low tpd,open drain |
| Sub-Family | Non-Inverting Buffer/Driver |
| Technology Family | AUP |
| VCC(Max) | 3.6 В |
| VCC(Min) | 0.8 В |
| Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5,3.3 В |
| tpd @ Nom Voltage(Max) | 26.5,14.4,9.4,9.7,6.7,9.7 нс |
- Development Kits: DLPLIGHTCRAFTER
DLPВ® LightCrafterВ™ Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: DLPDLCR4710EVM-G2
Full HD DLP4710 Chipset Evaluation Module
- Designing and Manufacturing with TI's X2SON PackagesPDF, 134 Кб, Файл опубликован: 23 авг 2017
- Understanding Schmitt TriggersPDF, 80 Кб, Файл опубликован: 21 сен 2011
Серия: SN74AUP1G07 (15)
- Semiconductors > Logic > Little Logic
