Datasheet Texas Instruments TMS320C14FNL — Даташит
СерияTMS320C14
МодельTMS320C14FNL
Процессоры цифровых сигналов 68-PLCC от 0 до 70
Datasheet
TSP
7 предложений от 7 поставщиков
Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 25.6MHz 6.25MIPS 68Pin PLCC
TMS320C14FNL
TMS320C14FNL
727GS
TMS320C14FNL
TMS320C14FNL
Pin6868
Package TypeFNFN
Industry STD TermPLCCPLCC
JEDEC CodeS-PQCC-JS-PQCC-J
Маркировка@1991 TITMS320C14FNL
Width (мм)24.2324.23
Length (мм)24.2324.23
Thickness (мм)4.064.06
Pitch (мм)1.271.27
Max Height (мм)4.574.57
RoHSНе совместим
  • A Universal Control Sys for Field-Oriented Control of AC Machines- TMS320C14
    PDF, 278 Кб, Файл опубликован: 1 июл 1997
    The purpose of this paper is to present a universal controller system used in field oriented control method of ac machines. This controller system uses one Texas Instruments (TI(TM)) TMS320C14 digital signal processor (DSP), four analog-to-digital converters (ADC), three operation amplifiers, two current sensors and a resolver. The digital values of sine and cosine functions of the rotor position
  • Symmetric PWM Outputs Generation with the TMS320C14 DSP
    PDF, 51 Кб, Файл опубликован: 1 июн 1997
    Pulse Width Modulated (PWM) signal generation is crucial to many motor and motion control applications. PWM signals are pulse trains with fixed frequency and magnitude and variable pulse width. There is one pulse of fixed magnitude in every PWM period. However, the width of the pulses changes from period to period according to a modulating signal. This document discusses how to generate symmetric
  • TMS320C1x Evaluation Module Analog Interface
    PDF, 173 Кб, Файл опубликован: 1 янв 1993
    The TMS320C16 evaluation module (EVM) is used to evaluate the performance characteristics of the TMS320C1x 16-bit fixed-point digital signal processor (DSP). This document builds a supplemental analog interface board that provides the analog capabilities commonly used by the DSP chip. This detailed document includes the schematics, the parts list, the cable connections, the power requirements, and
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
Серия: TMS320C14 (2)
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320C14FNL
