Datasheet Texas Instruments DAC2904Y/1K — Даташит
| Серия | DAC2904 |
| Модель | DAC2904Y/1K |
Двухканальный 14-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 48-TQFP от -40 до 85
Dual, 14-Bit, 125 MSPS Digital-to-Analog Converter datasheet
PDF, 885 Кб, Версия: C, Файл опубликован: 14 окт 2004
 Купить DAC2904Y/1K на РадиоЛоцман.Цены — от 621 до 2 981 ₽15 предложений от 15 поставщиков Микросхема Преобразователь DA, Dual-Channel, 14Bit, 125MSPS Digital-to-Analog Converter (DAC) 48-TQFP -40℃ to 85℃  | |||
| DAC2904Y/1K Texas Instruments  | 621 ₽ | ||
| DAC2904Y/1K Texas Instruments  | 1 132 ₽ | ||
| DAC2904Y/1K Texas Instruments  | 1 994 ₽ | ||
| DAC2904Y/1K Texas Instruments  | по запросу | ||
| Pin | 48 |
| Package Type | PFB |
| Industry STD Term | TQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | DAC2904Y |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Архитектура | Current Source |
| DAC Channels | 2 |
| Interface | Parallel CMOS |
| Interpolation | 1x |
| Package Group | TQFP |
| Package Size: mm2:W x L | 48TQFP: 81 mm2: 9 x 9(TQFP) PKG |
| Power Consumption(Typ) | 310 mW |
| Rating | Catalog |
| Разрешение | 14 Bits |
| SFDR | 80 дБ |
| Sample / Update Rate | 125 MSPS |
- Evaluation Modules & Boards: TSW2200EVM
TSW2200 Low-Cost Portable Power Supply Evaluation Module
- Wideband Complementary Current Output DAC Single-Ended InterfacePDF, 597 Кб, Файл опубликован: 21 июн 2005
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
Серия: DAC2904 (5)
- DAC2904IPFB DAC2904Y/1K DAC2904Y/1KG4 DAC2904Y/250 DAC2904Y/250G4
- Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
