Datasheet Texas Instruments PCA9518DWT — Даташит
| Серия | PCA9518 |
| Модель | PCA9518DWT |
Расширяемый пятиканальный концентратор I2C 20-SOIC от -40 до 85
PCA9518 Expandable Five-Channel I2C Hub datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 12 июн 2014
Купить PCA9518DWT на РадиоЛоцман.Цены — от 45 до 248 ₽32 предложений от 15 поставщиков Интегральные микросхемы Интерфейс - Специальное | |||
| PCA9518DWT Texas Instruments | 100 ₽ | ||
| PCA9518DWT Texas Instruments | 175 ₽ | ||
| PCA9518DWT Texas Instruments | 247 ₽ | ||
| PCA9518DWT Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | PCA9518 |
| Width (мм) | 7.5 |
| Length (мм) | 12.8 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Channel Width | 5 |
| Master Side I2C Bus Capacitance Supported | 400 пФ |
| Max Frequency | 400 kHz |
| Количество выходов | 5 |
| Package Group | SOIC |
| Slave Side I2C Bus Capacitance Supported | 400 пФ |
| Special Features | Enable Pin,EXP Pin,Open-Drain I/O Type |
| VCC(Max) | 3.6 В |
| VCC(Min) | 3 В |
| fSCLK(Max) | 0.4 МГц |
- Programming Fun Lights With TI's TCA6507PDF, 109 Кб, Файл опубликован: 30 ноя 2007
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: PCA9518 (9)
- Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
