Datasheet Texas Instruments CLVTH16244AIDGVREP — Даташит
СерияSN74LVTH16244A-EP
МодельCLVTH16244AIDGVREP
Усовершенствованный продукт 3,3 В, около 16-битный буфер/драйвер с выходами с 3 состояниями 48-TVSOP от -40 до 85
SN74LVTH16244A-EP datasheet
PDF, 707 Кб, Версия: F, Файл опубликован: 23 апр 2007
Pin48
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаLL244AEP
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits16
Тип входаTTL/CMOS
Рабочий диапазон температурот -40 до 125,-40 до 85,-55 до 125 C
Тип выходаLVTTL
Package GroupTVSOP
Package Size: mm2:W x L48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments CLVTH16244AIDGVREP
Публикации по теме
