Datasheet Texas Instruments TS5A23166DCURE4 — Даташит
СерияTS5A23166
МодельTS5A23166DCURE4
Аналоговый переключатель с двойным SPST, 0,9 Ом.
TS5A23166 0.9-О© Dual-SPST Analog Switch 5-V and 3.3-V 2-Channel Analog Switch datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 26 май 2015
2-канальный аналоговый переключатель 5 В/3,3 В. 8-VSSOP. От -40 до 85.
Package TypeDCU
Industry STD TermVSSOP
Width (мм)2
Length (мм)2.3
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
Additional FeaturesLow Harmonic Distortion
Low Power
Approx. Price (US$)0.28 | 1ku
Bandwidth(MHz)150
Bandwidth(Max)(MHz)150
Configuration1:1 SPST
Crosstalk(dB)Yes
ICC(Max)(uA)1
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Ron(Max)(Ohms)1.8
Ron(Typ)(Ohms)1.3
VCC(Max)(V)5.5
VCC(Min)(V)1.65
RoHSНе совместим
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A23166 (5)
  • Semiconductors > Switches and Multiplexers > Signal Switches > Analog Switch
На английском языке: Datasheet Texas Instruments TS5A23166DCURE4
