Datasheet Texas Instruments SN74LS145DR — Даташит
СерияSN74LS145
МодельSN74LS145DR
Декодеры/драйверы преобразования BCD в десятичное число 16-SOIC от 0 до 70
BCD to Decimal Decoders/Drivers datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 1 мар 1974
Pin16
Package TypeD
Package QTY2500
МаркировкаLS145
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Полоса частот35 МГц
Bits10
Количество каналов1
Configuration4:10
Digital input leakage(Max)5 uA
ESD Charged Device Model0.75 kV
ESD HBM2 kV
F @ Nom Voltage(Max)35 Mhz
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)13 мА
Output Drive (IOL/IOH)(Max)80/-20 мА
Schmitt TriggerNo
Technology FamilyLS
ТипStandard
VCC(Max)5.25 В
VCC(Min)4.75 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)50 нс
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Designing with the SN54/74LS123 (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74LS145DR
