Datasheet Texas Instruments BQ2004SNTRG4 — Даташит
СерияBQ2004
МодельBQ2004SNTRG4
Импульсное зарядное устройство NiCd/NiMH аккумуляторов с отрицательным dV, обнаружением пикового напряжения, оконечной нагрузкой dT/dt 16-SOIC от -20 до 70
Fast-Charge IC datasheet
PDF, 612 Кб, Версия: B, Файл опубликован: 19 апр 2005
Pin161616
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY250025002500
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаA4-A42004
Width (мм)3.913.913.91
Length (мм)9.99.99.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Absolute Vin (safety rating)(Max)(7 В
Battery Charge Voltage(Max)20 В
Cell ChemistryNiCd,NiMH
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3,4
Operating Vin(Max)5.5 В
Operating Vin(Min)4.5 В
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: DV2004L1
    BQ2004 Evaluation Module for NiCd/NiMH, linear
  • Evaluation Modules & Boards: DV2004S1
    BQ2004 Evaluation Module for NiCd/NiMH, switchmode, up to 3A
  • High-Side Current Sensing with Benchmarq's Fast-Charge Control ICs
    PDF, 31 Кб, Файл опубликован: 5 сен 1999
    A low-side, current-sensing resistor in a fast-charge control circuit generates a small voltage drop between the low side of the battery pack and ground. This drop is not a problem in most cases; however, some applications, particularly mobile communications circuits, are intolerant of any potential difference between the low side of the battery pack and ground. Using a few additional components i
  • Using NiMH and Li-Ion Batteries in Portable Applications
    PDF, 177 Кб, Файл опубликован: 5 сен 1999
  • Battery Charger Termination Issues With System Load Applied Across Battery (Rev. A)
    PDF, 151 Кб, Версия: A, Файл опубликован: 2 окт 2006
    Battery Charger Termination Issues With System Load Applied Across Battery While Charging
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ2004SNTRG4
