Datasheet Texas Instruments LM3409N/NOPB — Даташит
СерияLM3409
МодельLM3409N/NOPB
Понижающий контроллер PFET для приводов светодиодов высокой мощности 14-PDIP
LM3409, -Q1, LM3409HV, -Q1 P-FET Buck Controller for High-Power LED Drivers datasheet
PDF, 1.7 Мб, Версия: L, Файл опубликован: 23 май 2016
Pin14
Package TypeNFF
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаLM3409N
Width (мм)6.35
Length (мм)19.177
Thickness (мм)3.429
Pitch (мм)2.54
Max Height (мм)5.33
Dimming MethodAnalog,PWM
Входное напряжениеDC/DC Type
Iout(Max)5 A
Iq(Typ)2 мА
Package GroupPDIP
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Precision Dimming Control,Thermal Shutdown
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)50 kHz
TopologyBuck
ТипController,Inductive
Vin(Max)42 В
Vin(Min)6 В
Vout(Max)42 В
Vout(Min)1.24 В
Vref0.248 В
  • Evaluation Modules & Boards: LM3409EVAL
    LM3409 Demonstration Board
  • Dimming Techniques for Switched-Mode LED Drivers
    PDF, 425 Кб, Файл опубликован: 30 июл 2009
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • Driving LEDs: To Cap or Not to Cap
    PDF, 542 Кб, Файл опубликован: 21 мар 2007
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3409 (3)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3409N/NOPB
