Datasheet Texas Instruments MPC507AU/1K — Даташит
Серия | MPC507 |
Модель | MPC507AU/1K |
8-канальный аналоговый мультиплексор с дифференциальным входом 28-SOIC от -40 до 85
MPC506, MPC507:Single-Ended 16-Chan/Differential 8-Chan CMOS Analog Multiplexers datasheet
PDF, 727 Кб, Версия: A, Файл опубликован: 17 сен 2003
Pin | 28 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | MPC507AU |
Width (мм) | 7.5 |
Length (мм) | 17.9 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Additional Features | Dual supply,Powered off protection,Overvoltage Protection,Break-before-make |
Configuration | 8:1 |
Input/Ouput Voltage(Max) | 15 В |
Input/Ouput Voltage(Min) | -15 В |
Input/Output Continuous Current(Max) | 20 мА |
Input/Output OFF-state Capacitance(Typ) | 5 пФ |
Количество каналов | 2 |
OFF-state leakage current(Max) | 0.01 мкА |
ON-state leakage current(Max) | 0.01 мкА |
Package Group | SOIC |
Package Size: mm2:W x L | 28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG |
Rating | Catalog |
Ron(Max) | 1800 Ohms |
Ron(Typ) | 1300 Ohms |
Supply Current(Max) | 1500 uA |
Supply Current(Typ) | 700 uA |
Supply Range | 15 Max |
VIH(Min) | 4 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 15 В |
Vdd(Min) | 5 В |
Vss(Max) | -5 В |
Vss(Min) | -15 В |
- Multiplexer Data Acquisition SystemPDF, 71 Кб, Файл опубликован: 4 окт 2000
Multiplexers have been used for acquisition of quasi-static signals for a long time. While these signals usually have a low bandwidth of only a few hertz, applications generally require that the multiplexer send each signal as fast as possible to the converter and that the signals be processed quickly. To ensure fast processing, such acquisition systems usually include a sense amplifier behind the
Серия: MPC507 (3)
- MPC507AU MPC507AU/1K MPC507AUG4
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
