Datasheet Texas Instruments TL751L05QP — Даташит
Серия | TL751L05 |
Модель | TL751L05QP |
LDO с одним выходом, 150 мА, фиксированный (5,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 8-PDIP от -40 до 125
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Accuracy(%) | 4 |
Additional Features | Enable Overcurrent Protection Thermal Shutdown |
Approx. Price (US$) | 0.20 | 1ku |
Fixed Output Options(V) | 5 |
Iout(Max)(A) | 0.15 |
Iq(Typ)(mA) | 1 |
Operating Temperature Range(C) | 0 to 125 |
Output Capacitor Type | Cap Free Non-Ceramic |
Output Options | Fixed Output |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) See datasheet (CDIP) |
Rating | Catalog |
Vdo(Typ)(mV) | 600 |
Vin(Max)(V) | 26 |
Vin(Min)(V) | 6 |
Vout(Max)(V) | 5 |
Vout(Min)(V) | 5 |
RoHS | Не совместим |
- Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL751L05 (8)
