Datasheet Texas Instruments UC494AN — Даташит
СерияUC494A
МодельUC494AN
Расширенные регулирующие широтно-импульсные модуляторы 16-PDIP
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • DN-38 Unique "Cheap and Dirty" Converter for Low Power Bias Supplies
    PDF, 65 Кб, Файл опубликован: 5 сен 1999
    The UC495A PWM modulator provides a complete pulse-width modulation system in a single monolithic integrated circuit. Most-power supply designs use PWM controller ICs and MOSFET switches that require 10-15V bias supplies for proper operation. A common application problem is to first generate an auxiliary supply within this range. Although simple in many applications, developing this supply with a
Серия: UC494A (5)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC494AN
