Datasheet Texas Instruments LM2903DGKRG4 — Даташит
СерияLM2903
МодельLM2903DGKRG4
Двойной дифференциальный компаратор 8-VSSOP от -40 до 125
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
Pin888
Package TypeDGKDGKDGK
Industry STD TermVSSOPVSSOPVSSOP
Package QTY250025002500
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаMAPMAUMAS
Width (мм)333
Length (мм)333
Thickness (мм).97.97.97
Pitch (мм).65.65.65
Max Height (мм)1.071.071.07
Input Bias Current (+/-)(Max)50 нА
Iq per channel(Max)0.5 мА
Количество каналов2
Тип выходаOpen Collector
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Propagation Delay Time1.3 uS
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)28.5 В
Vos (Offset Voltage @ 25C)(Max)7 мВ
Vs(Max)30 В
Vs(Min)2 В
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM2903DGKRG4
