Datasheet Texas Instruments REG710NA-3.3/3K — Даташит
СерияREG710-33
МодельREG710NA-3.3/3K
Преобразователь постоянного тока в постоянный ток с переключаемым конденсатором, 30 мА и фиксированным выходным напряжением 3,3 В 6-SOT-23 от -40 до 85
REG710xx Buck-Boost Charge Pump with up to 60-mA Output Current datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 30 окт 2015
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаR10C
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Iout(Max)0.03 A
Iq(Typ)0.065 мА
Package GroupSOT-23
Special FeaturesEnable
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)1000 kHz
TopologyBuck/Boost
ТипCharge Pump
Vin(Max)5.5 В
Vin(Min)1.8 В
Vout(Max)3.3 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: REG710EVM-33
    Evaluation Module For Buck-Boost Charge Pump REG710
  • Evaluation Modules & Boards: REG710EVM-5
    Evaluation Module For Buck-Boost Charge Pump REG710-5
  • Optimizing Output Voltage Ripple for the REG710
    PDF, 56 Кб, Файл опубликован: 10 фев 2003
    Many portable power applications require a power source that has buck?boost capability with low output ripple. For this application, the REG710 is a prime choice; however understanding the affects of the pump and output capacitors allows designers to take full advantage of theREG710?s capabilities in order to minimize output voltage ripple.
  • Using the TPS3619 with MSP430 Microcontrollers Can Reduce Sys Power Consumption (Rev. A)
    PDF, 37 Кб, Версия: A, Файл опубликован: 19 май 2003
    The MSP430 series of microcontrollers are ideal in applications where battery life is critical. These microcontollers require only 0.1?A of current in low-power RAM retention mode; In this mode the microcontroller must have power to retain volatile memory. In some systems with charge pumps, the TPS3619 can be used to shut down the charge pump, saving system power consumption.
Серия: REG710-33 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Charge Pump (Inductorless)
REG710NA3.3/3K, REG710NA 3.3/3K
На английском языке: Datasheet Texas Instruments REG710NA-3.3/3K
