Datasheet Texas Instruments UC2825NG4 — Даташит
СерияUC2825
МодельUC2825NG4
Высокоскоростной ШИМ-контроллер 16-PDIP от -40 до 85
High Speed PWM Controller datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 24 фев 2004
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаUC2825N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCurrent,Feedforward
Duty Cycle(Max)80 %
Frequency(Max)1000 kHz
Frequency(Min)0.1 kHz
Gate Drive(Typ)1.5 A
Package GroupPDIP
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)30 В
Vin(Min)9.2 В
  • Qualifier TJ = TA Defined
    PDF, 22 Кб, Файл опубликован: 3 ноя 2010
    In the header of most datasheet specification tables there is a qualifier for the tests defined in the table,(TA = TJ, unless otherwise stated). Specifically, these tests are valid for the device as long as the junctiontemperature remains within the specified limits for that device.
  • U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power Supply
    PDF, 298 Кб, Файл опубликован: 5 сен 1999
    The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC2825NG4
