Datasheet Texas Instruments 74ACT11000NSRE4 — Даташит
Серия74ACT11000
Модель74ACT11000NSRE4
Четверные логические элементы положительного И-НЕ с 2 входами 16-SO от -40 до 85
Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 384 Кб, Версия: A, Файл опубликован: 1 апр 1993
Pin16
Package TypeNS
Industry STD TermSOP
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Approx. Price (US$)0.88 | 1ku
Bits(#)4
F @ Nom Voltage(Max)(Mhz)90
ICC @ Nom Voltage(Max)(mA)0.04
Тип входаTTL
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаCMOS
Package GroupPDIP
SOIC
Schmitt TriggerNo
Technology FamilyACT
VCC(Max)(V)5.5
VCC(Min)(V)4.5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)12.3
RoHSНе совместим
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Semiconductors > Logic > Gate > NAND Gate
На английском языке: Datasheet Texas Instruments 74ACT11000NSRE4
