Линейка продуктов KEEN SIDE
Datasheet Texas Instruments BQ24052DSQR — Даташит
СерияBQ24052
МодельBQ24052DSQR
Зарядное устройство для одноэлементной литий-ионной батареи, 1 А, с автоматическим определением переменного тока/USB, Rntc=100k 10-WSON
bq2405x 1-A, Single-Cell Li-Ion and Li-Pol Battery Charger With Automatic Adaptor and USB Detection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 дек 2014
Pin10
Package TypeDSQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаCGT
Width (мм)2
Length (мм)2
Thickness (мм).75
Pitch (мм).4
Max Height (мм).8
Absolute Vin (safety rating)(Max)(30 В
Battery Charge Voltage(Max)4.2 В
Battery Charge Voltage(Min)4.2 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)1 A
Control InterfaceStandalone (RC-Settable)
Control TopologyLinear
Number of Series Cells1
Operating Vin(Max)28 В
Operating Vin(Min)3.5 В
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Special FeaturesJEITA BAT Temp Monitoring (Thermistor Pin),Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source)
USB FeatureN/A
  • Automatic AC/USB Detection in bq24050/2/5 Using D+/D- pins
    PDF, 134 Кб, Файл опубликован: 25 янв 2010
    Modern day electronic devices, such as cell phones and MP3 players, can usually be powered with either an adapter or USB source through a single input connector using a mini USB cable. For a simple charger, without separate power paths for the system and the battery, the system (including the device transceiver) is powered directly from the battery. If the battery is deeply discharged, it has to
  • Selecting the Best bq2404x/5x/9x Single Cell Battery Charger for your Applicatio
    PDF, 38 Кб, Файл опубликован: 29 ноя 2012
Серия: BQ24052 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24052DSQR
