Оптопары и оптореле Megawin
Datasheet Texas Instruments TPS544C20RVFR — Даташит
СерияTPS544C20
МодельTPS544C20RVFR
4,5–18 В, 30 А SWIFT™ с PMBus™, возможность программирования и мониторинга напряжения, тока и температуры 40-LQFN-CLIP от -40 до 85
TPS544x20 4.5-V to 18-V, 20-A, and 30-A SWIFT Synchronous Buck Converters with PMBus datasheet
PDF, 3.2 Мб, Версия: B, Файл опубликован: 29 апр 2016
Pin40
Package TypeRVF
Industry STD TermLQFN-CLIP
JEDEC CodeR-PQFP-N
Package QTY2500
МаркировкаTPS544C20
Width (мм)5
Length (мм)7
Thickness (мм)1.46
Pitch (мм).5
Max Height (мм)1.52
Control ModeD-CAP,D-CAP2
Duty Cycle(Max)80 %
Iout(Max)30 A
Iq(Typ)8 мА
Package GroupLQFN-CLIP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Dynamic Voltage Scaling,Enable,PMBus,Power Good,Pre-Bias Start-Up,Remote Sense,Synchronous Rectification,UVLO Adjustable,Voltage Margining
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)250 kHz
ТипConverter
Vin(Max)18 В
Vin(Min)4.5 В
Vout(Max)5.5 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS544C20EVM-634
    30A D-CAP/D-CAP2 SWIFTВ™ Converter with PMBusВ™ and V, I, Temp Telemetry
  • Not All Jitter Is Created Equal (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 июл 2015
    This application report offers a tutorial discussion on jitter in switching DC-DC converters. Not all power supply designs are equally susceptible to jitter, nor are they equally affected by jitter. Modes of switching jitter are defined and explained for several popular control architectures, which are then analyzed for sources of jitter. An example contrasting the amount of jitter and effect on o
  • SMT Guidelines for Stacked Inductor (Inductor On Top) on Voltage Regulator IC
    PDF, 409 Кб, Файл опубликован: 22 фев 2016
Серия: TPS544C20 (2)
На английском языке: Datasheet Texas Instruments TPS544C20RVFR
