Datasheet Texas Instruments TPS25940LRVCT — Даташит
СерияTPS25940
МодельTPS25940LRVCT
18V, 5A, 42mО© eFuse With Integrated Reverse Current Protection and DevSleep Support 20-WQFN -40 to 85
TPS25940x 2.7 – 18V eFuse with True Reverse Blocking and DevSleep Support for SSDs datasheet
PDF, 2.8 Мб, Версия: A, Файл опубликован: 26 мар 2015
Pin20
Package TypeRVC
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка25940L
Width (мм)4
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
  • Evaluation Modules & Boards: TPS25940EVM-635
    TPS25940x Evaluation Module
  • Charging Super Capacitor With eFuse
    PDF, 682 Кб, Файл опубликован: 8 авг 2017
    Backup power management solutions are typically used in end equipment, such as solid state drives (SSDs), storage systems, data concentrators, and smart meters, where an unexpected power disruption can cause malfunction or data loss. Super capacitors or large hold-up capacitors are used as storage elements to provide enough backup power to maintain data communication prior to the whole system ’s s
Серия: TPS25940 (5)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS25940LRVCT
