Datasheet Texas Instruments UC3910N — Даташит
СерияUC3910
МодельUC3910N
4-битный ЦАП и монитор напряжения 16-PDIP от 0 до 70
Datasheet
TSP
IC DAC 4BIT 16DIP. DAC 4 bit Parallel 16-PDIP. Data Acquisition - ADCs/DACs - Special Purpose
UC3910N
351 ₽
Рутоника
UC3910N
Hi-Tech Circuit Group
UC3910N
UC3910N
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • U-158 The UC3910 Combines Programmability, Accuracy and Integrated Functions
    PDF, 491 Кб, Файл опубликован: 5 сен 1999
    As high-performance processors continue to develop, their respective power-supply requirements become more stringent, often requiring low, custom voltages and increasingly tighter regulation. Intel's Pentium(r)Pro power-system specification, for instance, demonstrates the need for tight regulation, programmable power-supply voltage, and programmable voltage monitoring for status reporting to the p
  • U-157 Fueling the Megaprocessor - A DC/DC Converter Design
    PDF, 678 Кб, Файл опубликован: 5 сен 1999
    This application note provides a detailed account of design tradeoffs and procedures for the development of a voltage regulator module (VRM) for the Intel Pentium (r)Pro processor. This voltage regulator features Unitrode's UC3886 Average Current Mode PWM Controller and UC3910 4-BIT DAC and Voltage Monitor ICs configured in a buck regulator. Test results and waveforms show how the VRM power supply
Серия: UC3910 (4)
На английском языке: Datasheet Texas Instruments UC3910N
