Datasheet ТI TPS71025DG4 — Даташит
| Серия | TPS71025 |
| Модель | TPS71025DG4 |
Стабилизатор напряжения с низким падением напряжения (LDO) 8-SOIC от 0 до 125
TPS71025 - Low-Dropout Voltage Regulator datasheet
PDF, 867 Кб, Версия: A, Файл опубликован: 12 май 1998
- Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TPS71025 (7)
- TPS71025D TPS71025DG4 TPS71025DR TPS71025DRG4 TPS71025P TPS71025PE4 TPS71025PWLE
