Datasheet Texas Instruments TRS232NSR — Даташит
СерияTRS232
МодельTRS232NSR
Двойной драйвер/приемник RS-232 с защитой IEC61000-4-2 16-SO от 0 до 70
Dual RS-232 Driver/Receiver With IEC61000-4-2 Protection datasheet
PDF, 926 Кб, Версия: A, Файл опубликован: 23 сен 2008
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаTRS232
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Data Rate(Max)120 kbps
Drivers Per Package2
ESD HBM2 kV
Logic Voltage(Min)5 В
Main Supply Voltage(Nom)5 В
Package GroupSO
Receivers Per Package2
  • Wave Solder Exposure of SMT Packages
    PDF, 206 Кб, Файл опубликован: 9 сен 2008
    It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
На английском языке: Datasheet Texas Instruments TRS232NSR
