Datasheet Texas Instruments SNJ54CBT16209WD — Даташит
СерияSN54CBT16209
МодельSNJ54CBT16209WD
18-битный коммутатор шины обмена 48-CFP от -55 до 125
SN54CBT16209, SN74CBT16209A datasheet
PDF, 760 Кб, Версия: O, Файл опубликован: 9 ноя 2004
Микросхема Чип аналогового переключателя, Bus Exchange Switch 1Element 9CH 48Pin CFPAK Tube
SNJ54CBT16209WD
340 ₽
SNJ54CBT16209WD
5 760 ₽
SNJ54CBT16209WD
TradeElectronics
SNJ54CBT16209WD
Pin48484848
Package TypeWDWDWDWD
Industry STD TermCFPCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY1111
CarrierTUBETUBETUBETUBE
МаркировкаADSNJ54CBT16209W5962-9669701QX
Width (мм)9.669.669.669.66
Length (мм)15.8815.8815.8815.88
Thickness (мм)2.482.482.482.48
Pitch (мм).635.635.635.635
Max Height (мм)3.053.053.053.05
Количество каналов18
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Ron(Max)8 Ohms
Ron(Typ)4 Ohms
Technology FamilyCBT
VCC(Max)5.5 В
VCC(Min)4 В
RoHSSee ti.com
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
Серия: SN54CBT16209 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Switches and Multiplexer > Signal Switch
На английском языке: Datasheet Texas Instruments SNJ54CBT16209WD
