Datasheet Texas Instruments SN74LVCH244ANSRG4 — Даташит
| Серия | SN74LVCH244A |
| Модель | SN74LVCH244ANSRG4 |
Восьмеричный буфер/драйвер с выходами с 3 состояниями 20-SO от -40 до 85
SN54LVCH244A, SN74LVCH244A datasheet
PDF, 1.6 Мб, Версия: O, Файл опубликован: 5 фев 2007
|  Купить SN74LVCH244ANSRG4 на РадиоЛоцман.Цены — от 4.21 до 21 ₽ 7 предложений от 7 поставщиков Микросхема Логический контроллер, Buffer/Line Driver 8CH Non-Inverting 3-ST CMOS 20Pin SOP T/R | |||
| SN74LVCH244ANSRG4 Texas Instruments | 4.21 ₽ | ||
| SN74LVCH244ANSRG4 Texas Instruments | 19 ₽ | ||
| SN74LVCH244ANSRG4 Texas Instruments | 21 ₽ | ||
| SN74LVCH244ANSRG4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | NS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LVCH244A |
| Width (мм) | 5.3 |
| Length (мм) | 12.6 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | SO |
| Package Size: mm2:W x L | 20SO: 98 mm2: 7.8 x 12.6(SO) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 6.9,5.9 нс |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
 When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH244A (19)
- SN74LVCH244ADBLE SN74LVCH244ADBQR SN74LVCH244ADBQRE4 SN74LVCH244ADBR SN74LVCH244ADGVR SN74LVCH244ADW SN74LVCH244ADWG4 SN74LVCH244ADWR SN74LVCH244ANSR SN74LVCH244ANSRG4 SN74LVCH244APW SN74LVCH244APWLE SN74LVCH244APWR SN74LVCH244APWRE4 SN74LVCH244APWRG4 SN74LVCH244APWT SN74LVCH244APWTE4 SN74LVCH244ARGYR SN74LVCH244ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
