Datasheet Texas Instruments SN65LBC184DG4 — Даташит
СерияSN65LBC184
МодельSN65LBC184DG4
Приемопередатчик RS-485 со встроенным подавлением переходных напряжений 8-SOIC от -40 до 85
SNx5LBC184 Differential Transceiver With Transient Voltage Suppression datasheet
PDF, 1.1 Мб, Версия: I, Файл опубликован: 30 июн 2015
29 предложений от 15 поставщиков
SN65LBC184DG4
118 ₽
Рутоника
SN65LBC184DG4
231 ₽
SN65LBC184DG4
372 ₽
SN65LBC184DG4
Package TypeD
Package QTY75
Маркировка6LB184
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-7 to 12
DuplexHalf
Fail SafeOpen
Fault Protection-15 to 15 В
HBM ESD15 kV
ICC(Max)25 мА
IEC 61000-4-2 Contact30 +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes128
Signaling Rate(Max)0.25 Mbps
Supply Voltage(s)(Nom)5 В
  • RS-485 at 230-kbps Over Uncontrolled Interconnect
    PDF, 408 Кб, Файл опубликован: 12 апр 2004
    This application report presents an evaluation of the SN65LBC184, SN65HVD22, and MAX487 transceivers in an uncontrolled impedance interconnection signaling at 230 kbps. The network used for the evaluation was identified as typical of that for building security.
  • RS-485 for Digital Motor Control Applications
    PDF, 180 Кб, Файл опубликован: 12 май 2003
    This application report focuses on the benefits of using RS-485 signaling for motor control and motion control applications. This technology has several benefits for these applications in terms of noise immunity, wide common-mode voltage range, adequate data rate, and multipoint capability. Other applications also use RS-485 signaling to take advantage of these same benefits. Applications such as
  • RS-485 for E-Meter Applications (Rev. A)
    PDF, 311 Кб, Версия: A, Файл опубликован: 6 авг 2004
    This application report discusses the best practices for designing energy meter communication circuits using the RS-485 standard. Component selection and performance tradeoffs are covered with reference to relevant standards such as IEC 61036 and DL/T 645. Reference design details are provided to help energy meter engineers successfully complete their own circuit designs.
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65LBC184DG4
