Datasheet Texas Instruments LM3532TME-40A/NOPB — Даташит
СерияLM3532
МодельLM3532TME-40A/NOPB
Высокоэффективный драйвер белого светодиода с программируемой функцией измерения окружающего света и совместимостью I2C 16-DSBGA от -40 до 125
LM3532 High-Efficiency White LED Driver With Programmable Ambient Light Sensing Capability and I2C-Compatible Interface datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 28 авг 2015
Pin16
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаD34
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Количество каналов3
Duty Cycle(Max)94 %
LED30
LED Current Per Channel30 мА
Package GroupDSBGA
Peak Efficiency89 %
Shutdown Current(Typ)1 uA
Special FeaturesOVP
Switching Frequency(Max)500 kHz
TopologyBoost
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)40 В
  • Evaluation Modules & Boards: LM3532EVM
    LM3532 Evaluation Module
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM3532 (2)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
LM3532TME40A/NOPB, LM3532TME 40A/NOPB
На английском языке: Datasheet Texas Instruments LM3532TME-40A/NOPB
