Datasheet Texas Instruments THS6132VFPG4 — Даташит
СерияTHS6132
МодельTHS6132VFPG4
Высокоэффективный драйвер линии ADSL класса G 32-HLQFP от -40 до 85
High Efficiency Class-G ADSL Line Driver datasheet
PDF, 469 Кб, Версия: A, Файл опубликован: 27 фев 2003
Pin32
Package TypeVFP
Industry STD TermHLQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Pitch (мм).8
Max Height (мм)1.6
2nd Harmonic(dBc)84
3rd Harmonic(dBc)92
@ MHz1
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)4.55 | 100u
АрхитектураCurrent FB
BW @ Acl(MHz)80
CMRR(Min)(dB)60
CMRR(Typ)(dB)67
GBW(Typ)(MHz)80
Input Bias Current(Max)(pA)15000000
Iq per channel(Max)(mA)7.5
Iq per channel(Typ)(mA)6.4
Number of Channels(#)2
Offset Drift(Typ)(uV/C)40
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)500
Package GroupHLQFP
Package Size: mm2:W x L (PKG)32HLQFP: 81 mm2: 9 x 9(HLQFP)
Rail-to-RailNo
Slew Rate(Typ)(V/us)300
Total Supply Voltage(Max)(+5V=5, +/-5V=10)33
Total Supply Voltage(Min)(+5V=5, +/-5V=10)6
Vn at Flatband(Typ)(nV/rtHz)3.5
Vos (Offset Voltage @ 25C)(Max)(mV)15
RoHSНе совместим
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
Серия: THS6132 (3)
На английском языке: Datasheet Texas Instruments THS6132VFPG4
